Team Yokomo MO 2.0 >
Team Yokomo MO 2.0
Like Tree44Likes
Team Yokomo MO 2.0
    Hide Wikipost
Old 02-12-2024, 01:07 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Yokomo MO 2.0
Last edit by: Cain
MO2.0 New Features:
NEW! Large capacity 13mm shock
NEW! Low height body
NEW! Laydown front and rear shock towers (rear short shock specification)
NEW! Lightweight front and rear bulkheads
NEW! Lightweight bulkhead cap
NEW! COL slipper unit (center one-way limiter slipper unit)
NEW! Main chassis (3 (mm long/COL slipper compatible)
NEW! Center bone (F/51mm, R/100mm)
NEW! Center mount (front)
NEW! Center mount plate
NEW! Servo mount & plate
NEW! Steering block plate
NEW! Front suspension arm (heavy duty)
NEW! High down force rear wing
Setups and other information:
Instruction Manual
Predator RC Front Bulkhead Brace & Predator RC Brace Pics
PetitRC YZ4SF2 Setups
PetitRC MO2.0 Setups
Yokomo spring chart
Vehicle check matrix (By Ray Munday)
Vehicle setup matrix (By Ray Munday)
Basic tuning for racing
SoDialed setup and pill calculator apps
How to Sand and Seal carbon fiber
Piston / Oil Tuning Chart
FAQ:
  • What is the difference between 2 gears and 4 gears in the gear diff? Please read these posts by Roger M.
Rear CVD Bone Modification to prevent bone ejection on crashes (Applies to MO1.0/SF2)
  • Part# YOKZ2-01065B 66.5mm Bone
  • Remove the 1mm shim used on the stock CVD
  • install the 66.5mm bone
  • Reassemble
Overdrive Front Gearbox When Using Smaller Diameter Tires
  • Credit to Will27
  • The parts for the front gearbox are S4-503D17 and S4-503R17
  • Useful will small diameter tires like the Jconcepts 2wd Front Wide tires
  • Must change back to stock with bigger tires other than Jcon PinSwag 4wd fronts
  • Better Flow through Long Corners
Print Wikipost
Old 09-05-2023, 05:02 AM
lexusbest's Avatar
Default Team Yokomo MO 2.0
https://teamyokomo.com/topics/14120/Introducing the Master Off-Road MO2.0, which brings out a sense of stability with smooth cornering while increasing the speed range!
Although the 4WD drive provides overwhelming propulsion, in today's off-road driving, which tends to behave quickly when cornering, the wheelbase has been extended, the Ackermann ratio has been revised, and a center one-way slipper has been adopted to improve stability. It is possible to run high. In particular, the newly developed one-way slipper activates when landing from a jump or entering a corner, eliminating overtraction on the front tire and making the bike's behavior milder. Furthermore, the capacity has been dramatically improved by adopting a Φ13mm big bore shock, which reliably absorbs shock from the road surface and improves the feeling of ground contact.
Cain likes this.
lexusbest is offline
Old 09-05-2023, 05:06 AM
lexusbest's Avatar
MO2.0 New Features:
Old 09-05-2023, 06:29 AM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Be curious on the revisions to the bulkheads and further improvement of the a-arm durability
Cain is offline
Old 09-05-2023, 09:18 AM
Curious to see what the price point of this will be - imo should be at a lower price than the 1.0 since they aren't including a center diff or rear aluminum carriers.
sawzall is offline
Old 09-05-2023, 11:31 AM
Curious if the Center one-way slipper will fit the SF2/M0 1.0... still looking for the M0 2.0 manual, looks like it hasn't been uploaded yet.
Obsidian is offline
Old 09-05-2023, 12:24 PM
^ lol. I was looking for the reverse. if the rear hub carriers and center diff from the 1.0 fit (and costs roughly what the 1.0 does), I'm willing to give the 2.0 a shot.
sawzall is offline
Old 09-05-2023, 01:42 PM
lexusbest's Avatar
I think it's 650$/€/£
Old 09-05-2023, 01:44 PM
lexusbest's Avatar
Would need at least old slipper front mount or maybe a bearing change?
Old 09-05-2023, 01:45 PM
lexusbest's Avatar
Yeah, that's a very interesting update. We'll see what can I fit to my still brand new not used MO1.0
Old 09-05-2023, 03:43 PM
The 1.0 is $699US at Amain. The way I look at it, the 1.0 center diff is $50US, and 1.0 aluminum rear carriers are $50US. So the 2.0 is really ~$750US to have it match the 1.0 parts. A $50 increase isn't too bad (but you're still not getting the carpet and dirt springs/swaybars).
I wonder if they'll come out with a dirt version - the current options included seem more carpet oriented.
petersen114 likes this.
sawzall is offline
Old 09-06-2023, 12:01 AM
lexusbest's Avatar
Both SO and MO 1.0 were a call for new customers. They couldn't keep selling full featured kits for the price they were selling. 0 option parts to sell.
The MO2.0 here in EU has been listed 50€ cheaper than the 1.0. It's 600€ compared to the 650€ of the 1.0
Old 09-06-2023, 09:24 AM
Tech Legend
Cain's Avatar
Yeah be curious if the USA price on this will be like $599 or so. I think they could benefit however by undercutting the B74.2 price in my opinion.
That said, I do wonder how much updates will be on the car material-wise as it looks like the SO 2.0 is getting a variety of carbon stuff
Cain is offline
Old 10-05-2023, 05:03 AM
Tech Legend
Cain's Avatar
In stock at Mibosport and manual has been posted:
https://teamyokomo.com/downloadfiles...ion_Manual.pdf
lexusbest likes this.
Cain is offline
Old 10-05-2023, 12:49 PM
I am really interested in that one way slipper.
Edit: Looking at the manual for the slipper. It is super intriguing and not at all what I expected.
Edit 2: It is almost like a slipper/ball diff combo.
Rfury is offline
Old 10-05-2023, 04:26 PM
Will27's Avatar
I'm guessing that the slipper's front drive cup MO-303DCB has a one way bearing inside? to allow it to only slip one way
Will27 is offline
